97 exhaust
97 exhaust
I've already decided to staight pipe it.Has anyone ever cut the cat and the muffler out in one shot ....if so can Ijust use one piece of pipe between ? looks like its offset a bit.Not worried about noise..truck has 180000 stock everything.
That´s what I did, and if you´re to learn from me, don´t place yourself under it when you cut it, it is kinda heavy, I learned.
But mine was bad from the cat back, so I made a new pipe with some 3" from my local shop.
Slev
Slev
I did a friends years back (mine is still stock until after camping season) and all i did was unbolted what I could then cut it just ahead of the cat or whatever it is- then I just cut the new 3" pipe at a slight angle to fit the off set perfectly. THe 12v is pretty loud... im looking for a good sounding muffler that wont break the bank.
why not go for a 4" turbo back set up and hang onto the cat, i put one on mine and it made a big difference, better spool up cooler running. a 5.9 = roughly a 350 ci running through 3"
pipe is pretty choked up, with the 4" engine breathes much better without to much noise added.
deere nut
10-06-2005 07:44 PM
greyrig05
03-31-2005 02:54 PM
Hoss
12-20-2004 11:13 AM
