2wd suspension?
2wd suspension?
Just wondering if there was a way to get a little lift on a 97 2wd 1 ton. Here recently I had to haul some equipment to an old arena and the road had some deep ruts along the way.I know I got close to a few bet managed to make it without any probs. If I had a little more clearance then i could have an easier time getting to more places .. TIA
Right, almost zero options for lifting the frame - I did mine by grafting the 4wd front frame section onto the rear section just under the seats, used the 4wd rear blocks.
Or you could find a 3500 gasser 4wd with a bad engine, switch everything over
not sure about the tire sizes, but no matter how much suspension lift you put on, you get zero additional ground clearance unless you put bigger tires on.
mtnman006
24
Sep 8, 2009 03:14 PM
Mr Bee
Sep 18, 2006 11:37 AM
Trebor
Sep 14, 2006 04:52 PM
