2nd gen, 12V, reg cab, short bed, 2WD, manual....exist?
Old Mar 6, 2007 | 06:40 PM
AnArKey's Avatar
So does this long list exist?
Needs to be:
2nd gen truck
12V cummins
Regular cab
Short Bed
Manual Trans
2WD
That's just what I really want. I'm expecting the answer to be something like "they made about 10 of them," or something.
The other option is to get a 1500, reg cab, shortbed, 2wd (easy to find and cheap), then build a bombed 12V with getrag and drop it in. From what I have read, I need a engine, trans, and rear axle from a 12V, 2wd.
Old Mar 6, 2007 | 06:46 PM
erics76's Avatar
I don't believe that Dodge ever made regular cab short bed 2500 or 3500 series. Could be wrong, but i've never seen one. I don't think you can just drop a diesel in a 1500 either. The suspension can't handle it.
Old Mar 6, 2007 | 07:02 PM
Mslaughter's Avatar
For a 2nd gen 2500 or 3500 your options are either std. cab long bed or ext. cab short bed (98+ I think) or ext. cab long bed. Doing a swap sounds like more work then it's worth. Just my $.02
Old Mar 6, 2007 | 07:14 PM
Forrest Nearing's Avatar
just buy a 2nd gen 12v 5sp single cab and cut the frame and put a short bed on it... that'll be your cheapest/easiest route
Old Mar 6, 2007 | 07:20 PM
wcbcruzer's Avatar
Yeah. OR, just get a std. cab long bed and be happy with it. The added weight of the extra 2 feet of bed isn't going to make a difference.
Old Mar 7, 2007 | 01:43 AM
1stGen545's Avatar
I agree with Forrest Nearing just cut a long bed frame and use a short box, lots easyer to find and the 1500 frount end will not handle the Cummins 1200+lbs. The 2500 and 3500 2wd don't last long.
Old Mar 7, 2007 | 09:53 AM
the 1500 rear end isn't THAT bad... there are a number of 1500's running around w/ 5.9's in them, but I'd rather have the 2500 brakes, etc.
and I'm looking at a total cost standpoint... it'll be cheaper dollarwise, but time is money, and it'll be a LOT cheaper there too!
you won't have to worry about vehicle inspection (if you have to worry at all) at 1500 will have to pass the gasser smog test, etc.
Old Mar 7, 2007 | 12:24 PM
patdaly's Avatar
I wouldnt want to ride too far with a 2500 SWB truck running empty.
At the very least have an industrial sized Kidney belt.
Old Sep 30, 2007 | 08:42 PM
SolarYellow05's Avatar
I'm in the process of building a reg cab short bed 2wd auto. Not very expensive if you do it yourself. Picked up a short bed with a linex for $600. Now all I need is a fuel tank, and get a driveshaft made. Looking at about $800 for the total conversion.
Old Jan 1, 2011 | 02:17 PM
GCSS's Avatar
I know this is an old link,
but for what it's worth....
I took a 1997 extended cab long box cummins (1997 5 speed)
and took 18" out of the frame just behind the cab. I did a little cab mount work, ,shortened the double driveshaft (took 18" from the rear-most tube)
got a fuel tank from a 1998-and up quadcab short box truck, found a box the same color(short box,mind you)and took out a factory 18" extension to the emergency brake cable,shortened he fuel line and brake lines done. Truck looks and drives great! I paid $300 for the box, and $35 for the fuel tank.
I even got a real nice tailgate too! AND...an accordion-style aluminum tonneau cover that works and looks good. Just the tonneau cover sells for just over $600.00 I know I got a good deal and finding the correct color box is what was the clincher for me to do this.
It took me one weekend to do.
I had the front end aligned to check the frame cuts and everything is perfect.
DJD
Audiophile31
Oct 28, 2021 10:19 PM
DJ Turbo.
Nov 5, 2011 12:20 AM
90 power ram
Oct 30, 2010 08:42 PM
schorb
Jul 1, 2004 06:25 PM
