255/85/16 picture?
Re:255/85/16 picture?
[quote author=BigBlue link=board=5;threadid=10412;start=0#106050 date=1045587826]<br>I run a 305/70/16 with slight rub at full lock. A 285/75/16 wouldn't rub at all.<br>[/quote]<br>I am supprised a 305/70 combo would rub. Isn't that tire barely 33" tall? Should be a shorter fatter tire right? hmmm... It is weird how some trucks can tuck bigger tires than others of same type...
Guest
Posts: n/a
Careful. After 2000, the rims for a 3500 have more offset. 2000+ will run 255-85/16s with no problem. You may be able to go a little wider and taller. 1999- may have some rubbing problems on the rear, depending on brand-name variation. <br>
Will the 255/85/16's look funny being that skinny? Anybody have a picture of 295/75/16's with Skyjacker 2-1/2" front springs? Will the 295's stick outside the fenders too much. If they did I would have to get fender flares. I really would prefer not to go with flares. ???
Guest
Posts: n/a
<br>Here's Gear Poet's truck. The 255-85/16 tires aren't skinny at all. They look OK, even with the lift. <br><br>
I just bought some chrome stockers this weekend [ truck did not come with them!] Put my 305 r70s on, dont rub at all! wrangler a/ts . I run a 33x12.50x16.5 bfg m/t on a 10 inch rim otherwise, no rub either! guy in my area has 6 315r 70 bfgs for sale that come off his duelly he bought it had slight lift but can buy the 6 for the price of 4 ! have 2000 miles on them!
When you change the tire size from stock can the truck change the speedo reading automaticaly or do you half to change speedo drive gears like in older cars? Just a question?<br><br>
The dealer can reflash for somewhat bigger tires, 275's sticks in my head.<br>Above is for the computerized 24 valvers.<br><br>There are also some aftermarket computer gizmos you can put on for bigger tires.<br>For the life of me I can't remember names or websites.<br><br>You might try a local speed shop, they might have a box for it.<br><br>Or, do what I'm going to do, use my GPS and ignore the speedometer. <br>Getting 35's sometime in the next month or so.<br><br>
j28s
11-04-2002 02:14 PM
