2006 Chevy wheels fit on my '99 dodge?
Old Sep 29, 2011 | 09:52 PM
Deezil's Avatar
Anyone have a break down of what fits what? Im looking for a deal on used wheels and am curious what will fit my 99 dodge 2500.
Thanks
Old Sep 30, 2011 | 03:06 PM
SIXSLUG's Avatar
I know the 99 and up Ford eight lugs will not.
I also think I read on here that Chevy changed the lug pattern for the Silverado HD's also.
You may need to stick with Dodge offerings. I got 17" wheels off an 04 for $50 each and they were like brand new.
Old Sep 30, 2011 | 11:37 PM
pind's Avatar
Stock for stock, GM/Chevy wheel center holes are too small to fit over the dodge/ford hubs.
Bolt pattern is the same, and you can use dodge, and old ford wheels on a chevy, but not the other way around.
Ford has also gone away from the 8 x 6.5 / 165mm pattern, to an 8 x 170mm pattern, just to confuse the issue further. I do believe that the new pattern came out on the early super-duty trucks in 99. Ford also has an 8 x 200 pattern, but that one is easy to spot.
Good luck with finding wheels
Old Sep 30, 2011 | 11:47 PM
Deezil's Avatar
so what about aftermarket wheels though? They still have the wrong centers for us if they are bought for a GM?
Old Oct 1, 2011 | 10:02 PM
pind's Avatar
"most" aftermarket wheels are androgynous.
The only ones I have run into that give trouble, are the Core Racing "Ambush" series, where you need special center cap extenders to clear the rear hubs on the dodge and ford.
In an aftermarket wheel, look for a 130mm or larger center hole in lug-centric wheels, and you'll be fine. For dually wheels, they can be a little more OEM specific, but once again, check the center bores.
Old Oct 2, 2011 | 02:28 PM
zthatzmanz28's Avatar
Thanks
Compare spacing and sizes here---
http://adaptitusa.com/referencebook.htm
joebishop23
Oct 29, 2007 10:19 AM
mike_ward
Aug 27, 2007 08:39 PM
Tommy93w350
Aug 5, 2007 08:16 PM
oldblues
Mar 23, 2007 09:44 AM
Tommy93w350
Jan 25, 2005 05:29 PM
