2001 fuel system
Old Dec 27, 2007 | 08:30 PM
jdunmyer's Avatar
2001 fuel system
I installed the Vulcan fuel pump relo kit a couple of days ago, and it went OK, but I have a question: Why does the kit NOT use the right-angle banjo fittings? The kit I got from Geno's Garage has 3 straight flare fittings that a swivel hose barb screws on to. Seems to me that it'd be as good or better to just use the old banjo fittings, perhaps with wormgear clamps instead of those darned spring thingys.
To do the above job, I had to have the tank below 1/4 full. As I had about 145 miles on it since fillup, I figured it was probably down about 10 gallons from full. Pumped out another 20 gallons, leaving about 5 gallons in the tank. Vulcan install went according to plan, so I checked the guage; it said nearly 1/2 full. Pumped in 10 gallons and it rose to about 3/4 full. Yet, it should be reading a bit below half, if my calculations are close to correct. I noticed while driving the truck for the couple thousand miles that I've owned it that it hangs on "full" for a long time, then drops more rapidly than it should. This is quite different from my 1994 CTD, that guage is nearly linear.
Is it possible to install a resistor in the guage circuit to make the guage less-optimistic? Has anyone else done this? It seems like I could splice in my sub box, spin the dials until the guage reads what it should, and go from there...??
Old Dec 28, 2007 | 07:23 AM
nkennedy's Avatar
I don't know about the fuel gauge, but the AN fittings with the Vulcan kit are less restrictive to fuel flow; therefore, better for the fuel system. More fuel flow, and less pressure drop.
Old Dec 28, 2007 | 02:26 PM
high country's Avatar
you could just bend the float arm.
Old Dec 29, 2007 | 11:11 AM
jdunmyer's Avatar
Well, except for having to drop the tank, maybe several times to get it right. :-(
Thanks for the info on the fittings!!
Old Dec 29, 2007 | 09:02 PM
azmusclecar's Avatar
My stock 2001 fuel gauge does the same thing, hangs on F for a long tiem and then heads south quickly.
Old Dec 30, 2007 | 12:14 PM
dj_souvlaki's Avatar
same with my 02. i'll be driving along with 300 km on the trip odo and 3/4 of a tank left thinking to myself oh ya this thing gets amazing miallege. than when i get to half a tank im at 400 km.
Old Dec 30, 2007 | 06:16 PM
WestTN's Avatar
The new Vulcan fittings have FAR less restriction than the banjo fittings. Those spring type clamps grip all the way around the hose and keep the connection tight as the hose shrinks and settles. Worm clamps don't apply uniform pressure around the hose, particularly under the worm mechanism. That is why no OEM supplies worm clamps.
Old Dec 31, 2007 | 12:18 AM
jack one side of the bed, pull the module and tweak the arm. drop the mod in and check it before the bed is lowered. you can do it in 5 minutes with the bed up.
Old Dec 31, 2007 | 12:32 AM
Redbeard's Avatar
My '01 does the same. Read that they all do. 100mi to 150mi it finally starts to drop fast. Never tried to mess with the float. Installed fass with the an fittings. No banjo fittings or stock filter. Less restriction on fuel flow. After the fass, edge comp, airaid intake, 4" MBRP, and larger injectors I got better mpg. Now it runs great. No more VP44 problems. Only had to go through 5 VP's and 7 lift pumps before I got smart and made the changes. Hope this info helps.
GKimPrice
47
Jan 6, 2015 11:06 PM
Dickson7
Mar 29, 2011 07:59 AM
John P
Apr 26, 2010 05:54 PM
gehaller
Feb 24, 2008 11:40 PM
Holycack
Jun 27, 2003 03:26 AM
