1996 2500 Fuel gauge does not work IDEAS ANYONE???
Old Feb 23, 2010 | 07:23 PM
  #31
GCSS's Avatar
Originally Posted by wyododge
Warmer shrarmer.
How do you expect to create any new words if you don't crack you knuckles when their cold????
I did my share of cold weather knuckle-bustin'......
I'll just keep the tank topped off... warmer weather is just around the corner.
Old Feb 24, 2010 | 12:49 AM
  #32
VICIOUS FISHER's Avatar
Originally Posted by GCSS
I tested it as you said...the gauge climbs when I grounded it out.
sender is bad!
Thanks guys!
awesome, glad to hear you are on the right track.....nothing worse than doing it twice
Old Feb 26, 2010 | 11:13 AM
  #33
400Magnum's Avatar
For you guys that rebuilt/replaced the sending units, the factory service manual also says that you need to replace the ring and seal at the top of the sending unit that holds it to the tank. Did you replace those too or just re-use the old ones?
Old Feb 26, 2010 | 12:07 PM
  #34
justme-'s Avatar
first time I did not replace the ring and it leaked, second time (first time I replaced the sending unit, 2nd time I rebuilt it) I replaced the gasket but not the locking ring, no leaks using fuel as lube on the sealing ring.
Old Feb 26, 2010 | 12:49 PM
  #35
infidel's Avatar
I keep a new one of each on hand because I do so many replacements but have only had to use one ring in the last ten years because the old one cracked.
No leaks otherwise.
mycomike
Aug 6, 2015 11:50 AM
skahla
Nov 20, 2009 08:13 AM
heykw
Oct 24, 2007 11:53 PM
wcbcruzer
Feb 24, 2007 08:33 AM
big green
May 6, 2005 11:31 AM
