1995 Ram 2500
Old Nov 26, 2006 | 04:33 PM
fruitcakesa's Avatar
1995 Ram 2500
Hi Folks,
I need a little advice on what to look at and for on an original owner 95 Cummins Ram 4x4. 172k miles mostly as daily transportation. 5 speed with 3.55 axles. Original clutch and trans. Original untouched engine. He has replaced balljoints and axle ujoints, steering box, shocks and brakes but has original rotors, starter,water pump and belt. Done the work himself. I am going to look at it tomorrow so any help would be appreciated.
Andrew Leven
Old Nov 26, 2006 | 07:01 PM
dslpower's Avatar
Ask if the KDP has been taken care of. Other than normal things to look at rust on frame and body, ANY leaking seals (engine,trans or rearend), any butchered up wiring or other system.
If the engine has not been turned up then everything should be in good condition.
Old Nov 26, 2006 | 07:07 PM
Kdp?
Thanks dslpower for the info. I am a newby when it comes to Cummins. What is the KDP and what should be done about it?
Old Nov 26, 2006 | 07:37 PM
blazinchuck's Avatar
I think that means Killer Dowl Pin...I haven't done mine yet either-just got my truck. But everyone says this little dowl pin can crack the block if it backed out and fell. It is in the front- I think behind the lower timing cover. Maybe someone that knows will shead some light on it for you and I,HTH,Chuck
Old Nov 26, 2006 | 07:48 PM
TIMMY22's Avatar
whats he askin for it?
check front cover for leaks or cracks. if you are not familiar with the front end, have a shop look it over (they can get pricey to repair) good bargaining tool. take it for a good ride. the 5 speeds had trouble with 5th.
Old Nov 26, 2006 | 08:35 PM
TxDiesel007's Avatar
I agree here
but if its a 4wd, do expect the usual, trackbar, needs an alignment, and possibly the shocks as well..
Rick
Old Nov 27, 2006 | 08:11 PM
CarlJensen's Avatar
Here is the explanation of KDP (Killer Dowel Pin)..
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Nov 28, 2006 | 08:34 PM
I bought the truck for $6300.
Old Nov 29, 2006 | 08:07 AM
waldersha's Avatar
Sounds like a pretty good deal. Now start doing your research and fix the little things. You'll love the cummins. Welcome to the site!
snic
15
Jun 14, 2017 11:29 AM
EJ RAM
May 12, 2014 09:55 PM
Will Willard
Jun 7, 2013 05:30 PM
Tacomaman87
Aug 9, 2007 07:57 AM
