'01 & '02 rear disc brakes
Old Feb 16, 2009 | 02:11 PM
Mechanos's Avatar
Does anyone know who the manufacture is that makes the rear disc brake setup on the '01 & '02 2500 & 3500? I'm assuming that it's a brake company like Bendix, etc.
Old Feb 16, 2009 | 03:18 PM
Erik@LCD's Avatar
might be cheaper and easier to find an 02 disc brake rear.
Old Feb 16, 2009 | 09:23 PM
Mechanos's Avatar
Thanks... but that has nothing to do with my question. I have an '01.5 2500 that already has rear disc brakes. I just want to know who makes them.
Old Feb 17, 2009 | 09:06 AM
Mechanos's Avatar
After more poking around... I think they might be TRW. The calipers look like TRW RPS calipers and the backing plates also like TRW's. But, I'm still looking for confirmation.....
Old Feb 18, 2009 | 06:26 AM
zukota's Avatar
Doing my front's last night, the caliper bracket is stamped TRW...
Old Feb 18, 2009 | 07:58 AM
Mechanos's Avatar
Thanks... that helps. The front and rears are the same type of setup. The brackets and calipers are slightly different though. But, if the fronts are TRW then I'd lay money on the rears being TRW as well.
Old Feb 18, 2009 | 09:30 AM
zukota's Avatar
Yeah.
I did my rears last week but I wasn't looking. I do recall that the rear calipers had a chrysler stamp cast into them... Regardless it's a very similar, caliper, spring clips on the bracket and bracket mount - but obvisouly not identical.
Old Feb 22, 2009 | 08:52 AM
KevinG19yrsArmy's Avatar
How's it going?
I'm going to change rotors and pads all around on my 02 2500, most likely next weekend. Quick question...both front and rear have rotors that slide off and slide on, right?...meaning I don't have any bearing assemblies to take apart...is that correct? Appreciate any advice.
Old Feb 22, 2009 | 09:24 AM
gmctd's Avatar
F\R SRW rotors slide off after removing the stud-clips - DRW rear rotors require hub removal and disassembly, as rotor is mounted to the back of the hub, similar to drum-brakes
Old Feb 22, 2009 | 06:42 PM
TMWeber's Avatar
Originally Posted by KevinG19yrsArmy
How's it going?
That is correct. Very simple to do.
Old Feb 23, 2009 | 12:27 AM
wyododge's Avatar
Hey Mechanos, I took pictures of the location of the adjuster for the e brake on rear disc brakes. There is a BR stamped on the back of the housing. Does that help???
the pictures are -> here
1992 Renegade
Oct 11, 2014 03:29 PM
2500CTD
Oct 19, 2010 07:10 PM
ShawnQ
Jan 12, 2006 08:09 PM
kwhite4
May 9, 2005 03:22 PM
drafalske
Sep 15, 2004 06:46 AM
