Mark this thread as Unsold
Truck For Sale 2001, White, Ext cab, cummins 2500, 8ft bed, 5-Speed, 4X4
Up for sale is my 2001 Dodge Cummins 4X4 5-Speed. The list of new parts and work done is extensive, but I'll try not to leave anything out. Feel free to call/text with any questions or for more pictures. I love the truck and engine and am only selling because the maintenance has turned out to be a little more expensive than I planned on and I do not really need this big of a truck.
New Stuff
-fuel level sending unit
-headlights
-injector fuel lines and delivery tubes
-Big Honkin Air Filter and Custom Heat shield, also includes factory air box
-front main seal and timing cover seal
-timing pin O-ring
-valve cover gasket and valve adjustment
-Bosch alternator
-Dayco belt and tensioner
-washer fluid reservoir
-all driveline fluids, front and rear diffs, transmission and transfer case
-PA state inspection good until July 2016
-Cooper StarFire Tires with less than 3,000 miles
-ordnance style battery terminals and new ends on cables
-black nerf bars
-harmonic dampener
Other Accessories
-75hp BD Diesel injectors
-Fass 95HPFP lift pump relocated to frame rail
-Recently rebuilt injector pump
-Recently replace wheel bearings
-SMARTY SO-3
-Autometer Z-Series Boost, Pyro, and Fuel pressure gauges in pillar pod
-4X4 cable actuator instead of the factory vacuum setup
-Brake controller
-Minimal rust which I have been working on fixing(frame and under body are very clean!)
-fiberglass cap in good condition
-4" turbo back straight pipe
My asking price is $15,500. I know that is kinda high but that(or close to it) is what I need to make it worth selling after all I've put into it. As I said above I do not need to sell it. I will negotiate some but not too much. I am located in Watertown, NY.
Feel free to text, call, or email with any questions or for pictures.
My number is 484-387-0662 and my email is leathermaneod@me.com
Nate
New Stuff
-headlights
-timing pin O-ring
-Bosch alternator
-black nerf bars
-harmonic dampener
Other Accessories
-SMARTY SO-3
-Brake controller
Nate
Dean400
May 14, 2011 04:55 PM
mcolectd
Sep 19, 2010 08:46 PM
IlikeDodge
14
May 23, 2010 04:48 PM
