2001, White, Ext cab, cummins 2500, 8ft bed, 5-Speed, 4X4
Up for sale is my 2001 Dodge Cummins 4X4 5-Speed. The list of new parts and work done is extensive, but I'll try not to leave anything out. Feel free to call/text with any questions or for more pictures. I love the truck and engine and am only selling because the maintenance has turned out to be a little more expensive than I planned on and I do not really need this big of a truck.
New Stuff -fuel level sending unit -headlights -injector fuel lines and delivery tubes -Big Honkin Air Filter and Custom Heat shield, also includes factory air box -front main seal and timing cover seal -timing pin O-ring -valve cover gasket and valve adjustment -Bosch alternator -Dayco belt and tensioner -washer fluid reservoir -all driveline fluids, front and rear diffs, transmission and transfer case -PA state inspection good until July 2016 -Cooper StarFire Tires with less than 3,000 miles -ordnance style battery terminals and new ends on cables -black nerf bars -harmonic dampener Other Accessories -75hp BD Diesel injectors -Fass 95HPFP lift pump relocated to frame rail -Recently rebuilt injector pump -Recently replace wheel bearings -SMARTY SO-3 -Autometer Z-Series Boost, Pyro, and Fuel pressure gauges in pillar pod -4X4 cable actuator instead of the factory vacuum setup -Brake controller -Minimal rust which I have been working on fixing(frame and under body are very clean!) -fiberglass cap in good condition -4" turbo back straight pipe My asking price is $15,500. I know that is kinda high but that(or close to it) is what I need to make it worth selling after all I've put into it. As I said above I do not need to sell it. I will negotiate some but not too much. I am located in Watertown, NY. Feel free to text, call, or email with any questions or for pictures. My number is 484-387-0662 and my email is leathermaneod@me.com Nate |
