Will not start
Old Jun 13, 2007 | 07:18 PM
jpolston's Avatar
Will not start
My truck will not start....any ideas?
I've checked the fuel pressure.....~14psi when first swithed on.
Drained and changed the fuel filter, reprimed.
Put 20 gals of fresh diesel in tank
Fuel pump runs when switched on
Still will not start.
Old Jun 13, 2007 | 07:21 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
well, whats happening? Does it just turn over and doesn't catch like there is no fuel? Or does it start to catch, cough and spit white and black smoke and then just die?
Old Jun 13, 2007 | 07:23 PM
iforge03's Avatar
get a code reader and see if will read anything. if it cant communicate with ecm, your ecm is bad. i had that happen to me not to long ago.
JPR Ram's Avatar
I'm thinking maybe the vp took a dump. But with out more info, our guess' are just that, guess'.
Old Jun 14, 2007 | 05:48 AM
jpolston's Avatar
I'm actually travelling, my son has borrowed my truck, and it and he are at home with it. I've been troubleshooting over the phone with him. It is spinning over fine, acts like it is not getting fuel. I've had him do the most obvious checks he can do. I'm was hoping it was not the ECM or IP.
What is the procedure for reading the codes?
Thanks for the help.
Old Jun 14, 2007 | 07:37 AM
patdaly's Avatar
key on-off-on-off-on then read the codes in the odometer.
Old Jun 14, 2007 | 04:45 PM
jpolston's Avatar
The codes are:P0500, P0460, P1693. I'll do a search for the codes. This is a 2001 ETH
How do I clear the codes? Will it reset the ECM when I clear the Codes?
Also, should I be able to hear the pump in the tank running when I switch it on? There is a pump in the tank that feeds the lift pump right?
Thanks for any help or ideas.
TXJClark
Dec 6, 2014 05:50 AM
Hunky Dory
May 13, 2013 08:09 PM
FirstGen1991
Dec 22, 2012 04:24 PM
CoolumConst
Oct 11, 2008 10:00 PM
loosendend
Sep 4, 2006 12:01 PM
