will this hurt my engine?
Old Jul 2, 2007 | 11:47 PM
hillbillymudrun's Avatar
When i put on my ejw/a i started drilling in the wrong spot on my exhaust menifold. It didnt go all the way through but i must have came really close because tonight i started hearing a whistleing sound and checked it out when i got home and it is coming from that hole (see pic) Is there anyway to fix this without replacing the manifold?
Old Jul 3, 2007 | 02:18 AM
wcbcruzer's Avatar
No it won't hurt your engine, but yes it will hurt your performance. Tap it and stick a bolt in there to seal it up.
Old Jul 3, 2007 | 02:39 AM
if i put a bolt in there wont if block the flow of the exhaust and not spool the turbo as much? i am still getting 20psi wot on it now
Old Jul 3, 2007 | 02:42 AM
dc10freighter's Avatar
Theres a permatex type stuff in a tube, it will seal the hole with the bolt.
Old Jul 3, 2007 | 02:44 AM
wcbcruzer's Avatar
No, just try to get a real short bolt. The hole doesn't look very big so you should be able to find a short bolt for it. Having a leak in the pressure side of the manifold is worse than having a bolt sticking in there imo. Bolt won't hurt it anyway. Some guys have run two pyro probes in the manifold before. And you know the pyro probe is pretty big.
Old Jul 3, 2007 | 02:57 AM
thats true i didnt think about the pyro the hole is only 1/8 inch it was the pilot hole I guess i will be doing that tomorrow thanks for the help
Old Jul 3, 2007 | 02:58 AM
Dc10freighter where abouts oregon are you
Old Jul 3, 2007 | 09:24 AM
D2 Cat's Avatar
If you don't want to tap it you could take it to a weld shop and have them plug it. It wouldn't take much time or effort!
Common
May 7, 2010 11:21 PM
ron b
21
Oct 2, 2008 07:27 PM
FSTDL
Aug 18, 2008 05:36 PM
MNorby
Jan 24, 2006 07:19 PM
Bad Ramer Jamer
Dec 12, 2005 01:01 PM
