will this edge chip work in my truck
Old Feb 20, 2010 | 09:46 AM
BakerBoy's Avatar
i just recently bought a 1999 dodge 3500. a buddy of mine gave me a edge ecd 2000b, on the back it says it is for a 2002. i am pretty sure his old truck was a 2000 and he had it on their. i was just wandering if this chip would work on my truck
Thanks, Baker
Old Feb 20, 2010 | 02:09 PM
lovinCTD59's Avatar
I dont THINK it will. I believe its a different wiring harness, and it may have to be reflashed to work correctly..
Old Feb 20, 2010 | 10:00 PM
BakerBoy's Avatar
well thanks for the response, looks like i am going to have to buy a new chip or do some trading around with someone. if anyone has a 2002 and needs a edge drag comp box let me know maybe we can do some trading for something that will work for my 99
Old Feb 22, 2010 | 07:59 AM
RowJ's Avatar
If it worked on his 2000, will work on your 1999.
Difference is in the MAP sensor plugs, I believe.
If it will hook up (plug in), it should work.
There are adaptors for earlier models to later model trucks. Maybe they have the reverse as well??
RJ
Old Feb 23, 2010 | 11:52 PM
BakerBoy's Avatar
well thank you for the input, now i just got to try to find some time to pop the hood and see if it will plug up. by any chance does anybody know what those chips are worth? i was thinking around 350 or so but i am not sure, i still new to the 24 valves and havent got my 12 valve out of my blood yet
Old Feb 24, 2010 | 04:13 AM
madhat's Avatar
Administrator/Jarhead
Get the model number, call edge, or look at their website. They have great customer service.
That programmer is worth what someone will pay for it. If he is your friend, be good to him. If not, low ball it.
With the 24's, (If it is a VP) you're probably going to want to tap your pump to get good power. If you do this, I would suggest that you get an aftermarket LP and closely monitor your fuel pressure. Those VP44's are known for failing if you starve them.
I have helped 1999blackcloud with his 99, talk to him if you have questions.
Good luck!
Old Feb 24, 2010 | 07:30 PM
BakerBoy's Avatar
thanks madhat for all the advice. i am going to tap the pump and definitly get a better lift pump soon, i am going to try that chip i just wanted to make sure i am not gonna fry my ecm or something if its not for that year
Old Mar 3, 2010 | 08:58 PM
jimmyray2006's Avatar
Thanks, Baker
Wanted to trade ad removed
gergthegreat
Dec 30, 2008 09:19 PM
bansh-eman
Jan 27, 2008 02:48 AM
Elk_Hunter
Oct 24, 2006 03:17 PM
cowdude
Feb 19, 2003 06:20 PM
