Wierd thermostat Issue
On the drive from Colorado to Nebraska the truck ran amazing in the cold. I got 4 miles from Omaha and suddenly my coolant temps sky rocket. Turns out the water pump took a dirt nap and an entire radiator worth of coolant baithed my engine bay. Got to my brothers and changed out the water pump(thank god they are so easy on these things), and refilled the antifreeze. I also changed the thermostat with the 190 degree replacement. Before my temps were a rock solid 188 degrees no matter what I did. Now with the new thermostat my temps cycle from 195 degrees to 208 degrees up and down. Is this too hot for this engine? Thanks for the help.
Bryan
Bryan
If you had gone to a certified Cummins shop, They would have asked for the motor # and given[sold] you the proper 180 degree that Cummins calls for. Only a Cummins part should go in there or you will be plagued with temperature swings instead of the rock steady 180 that the Cummins part will give you.
01's require a 190 and were delivered new with it. A 180 is fine, however.
Diesels like it hot and run well in that temp range.
208 isn't really that hot. I wouldn't sweat
a 13 degree variation. You're fine.
Kurt
a 13 degree variation. You're fine.Kurt
Bookshelf
May 30, 2009 01:17 AM
95turbo4wd
Jan 2, 2008 09:32 PM
