Where to tap into trans lines
Old Jun 19, 2011 | 11:28 AM
cstmfabman's Avatar
I asked on another thread and no response, so I'll try again, no usable information on search either . I am installing an aux trans cooler and I don't know which line I should be tapping into. Is there a barbed fitting that I can install directly on the radiator (or stock cooler) for the one side, and do I have to flare the stock trans line , or is there a fitting that can be screwed onto it also? I know lots of people on this site have installed aux trans coolers, just looking for a little information
Old Jun 19, 2011 | 12:09 PM
wlowe's Avatar
Below is a link to the install instructions for the Super Cooler that I installed on my transmission, might give you some ideas for your install. I used compression fittings that came with the kit. The instructions show where to cut the lines and install fittings.
http://proweldperformanceparts.com/S...ers/index.html
Also, here is a link to some of the parts.
http://proweldperformanceparts.com/S...cessories.html
Old Jun 19, 2011 | 05:10 PM
cstmfabman's Avatar
Thanks! I will look into that!
Old Jun 20, 2011 | 08:13 AM
Ed ke6bnl's Avatar
What is the length and width of the cool coil assembly thanks ED I need to add a trans cooler to my transmission.
Old Jun 20, 2011 | 08:00 PM
wlowe's Avatar
The cooler that came with my kit is a B&M hi-tek cooler with a thermostatically controlled fan attached. This cooler comes in two different sizes but I believe the one I have is the small one in the link below, (10" X 7.5"):
http://www.summitracing.com/parts/BMM-70298/
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
alto22
34
Feb 16, 2007 09:28 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
