Where to put EGT probe on manifold tap?
Where is the best pace to tap the exhaust manifold pre turbo? Anywhere on the manifold OK?
Just asking before I drill a hole in the wrong spot!!!
THanks for the advice in advance!
Ok that sounds good to me. Putting it on top is good then I guess. I usually tap from the bottom on my last truck but your pic looks like a good spot. I just want good readings of the EGTs. Thks!
Make sure you don't try to drill right in the center of the manifold, as there is a divider between the front and rear halves. Stay towards the rear, as the photo indicates.
Yes, this is VERY important. I bought a truck 2 years ago and the thermocouple was "crooked" due to installation in center of manifold.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
06Cummins
05-23-2006 11:58 AM
