4.30's for the dana 70U
Old Feb 1, 2008 | 02:05 PM
Thedieselkid's Avatar
I am wondering if anyone knows where I can get 4.30's that will fit my current carrier for my dana 70u? I have been striking out. I can find them for the 60. I would like to go with 4.30's then i don't have to change my carriers.
Thanks
Old Feb 1, 2008 | 08:47 PM
anyone...anyone at all?
Old Feb 4, 2008 | 11:52 AM
haloman's Avatar
Did you try Randy's ring and pinion?
Old Feb 5, 2008 | 05:46 AM
I looked on that site but did not see anything listed. I will prob give them a call today.
Old Feb 5, 2008 | 11:45 AM
CTD NUT's Avatar
To the best of my knowledge, there is no 4.30 gear for a D70. Why not just go with the 4.56's?
Old Feb 6, 2008 | 06:07 AM
CTDNUT - I was trying to avoid swaping the carriers. What it looks like I am going to do now is go with the 4.56's. The rear will be a 4.56 thick gear so I can use the same carrier and not worry about the abs. The front I will put a new carrier in and 4.56's.
I have two questions - The abs for the front is on the axle and not the diff right? Two, should I get the master install kit for the front and back or just a couple shim packs?
Thank you,
Old Feb 6, 2008 | 07:14 AM
CTD NUT's Avatar
The front ABS sensors, if equipped, are located in the bearing hubs and will be uneffected by carrier changes. If you are not changing the rear carrier during the gear install, I would still suggest the master kit since it is worth while to install new carrier bearings during the gear swap. I'm not sure why you don't want to change the rear carrier? The thicker gear tends to leverage the carrier more which can lead to additional deflection under heavy load - read weaker. For your application and power level, using the thick gear would not be a wise choice.
Old Feb 6, 2008 | 08:19 AM
Ok I was trying to save a few hundred dollars but I would rather do it right the first time. Thank you for the help...i will continue to save
Old Feb 10, 2008 | 12:05 PM
CTDNUT- I was told that I have to do some fabrication to make the abs work if I change the rear carrier. What is your opinion? I was told that the tone ring is on the carrier and that if I change the carrier I need to change the sensor location.
Also, with 37's should I upgrade to 35spline rite away since I plane to drag race and pull...just wondering.
Thank you,
Paul
rockmike
May 12, 2012 05:20 PM
Bullbythehorns
Jun 15, 2007 12:40 PM
JKM
Off Road / 4x4
22
Jun 5, 2007 11:31 PM
johnny5.9
Mar 4, 2007 06:41 PM
w250_93
Feb 23, 2007 07:10 AM
