where is my drain plug???
Old Jun 13, 2003 | 08:18 PM
owtlaw's Avatar
I would like to change the fluid in my 6 sp. nv5600 but I can't find the drain plug. I see 2 pto covers and the big nasty looking allen headed plug half way up which is where you fill it at I assume,but no drain plug. Also I just changed my rear diff oil. 4 qts. is what I put in and the level is 1/2&quot; below the drain plug is that allright?<br><br>jason
Old Jun 13, 2003 | 08:47 PM
owtlaw's Avatar
Re:where is my drain plug???
How many qts of MTL will I need?
Old Jun 15, 2003 | 10:30 PM
HeberRam's Avatar
The correct amount is 9.5 pints. As so many have said to put 8 pints in the 17mm fill hole is almost impossible no matter what angle the truck is, simply take out the highest bolt on the PTO cover, insert a 1/4 plastic tube and pump in the rest. <br><br>Steve
klx650a2
Jan 10, 2008 12:08 AM
wooff
May 1, 2003 11:22 AM
Dodgezilla
Nov 24, 2002 07:31 AM
cpermd
Oct 28, 2002 02:19 PM
