where to hook up attitude fuel pressuer up to air dog
Old Jan 16, 2010 | 10:23 AM
mnester's Avatar
just put the air dog 100 on my truck dont know where to hook up the fuel pressure for the attitude. or do i need to rig up something myself to make it work
Old Jan 16, 2010 | 10:33 AM
CamperAndy's Avatar
There is no option that I know of for connecting an external fuel pressure sensor to the attitude. You will want to get a stand alone gauge to monitor your fuel pressure.
Old Jan 16, 2010 | 11:12 AM
onelugnut's Avatar
It looks like the attitude sending unit will fit in to the same port as the airdog psi light kit. I am still doing the install and will look in to it over the weekend. Wish me luck
Old Jan 16, 2010 | 05:01 PM
sheriffav8r's Avatar
I don't have the airdog, but do have an aftermarket pump. I just put the sending unit on the end of a tee off the fuel line after the fuel filter. I also have an adjustable damper on it because I had a Quad Commander on it before and it was a POS for the fuel sender. Just put a tee in the line (Home Depot type brass) and screw the sender into a brass fitting that you can insert into the tubing to clamp with a hose clamp.
robinlh
Apr 17, 2011 07:10 AM
trailinone
16
Jun 19, 2009 04:28 PM
CowboyDave
14
Dec 18, 2006 10:30 AM
redruM Hauler
Dec 14, 2005 05:59 AM
