Raise in my "normal" Fuel Pressuer
Old Apr 16, 2011 | 06:31 PM
robinlh's Avatar
After replacing my vp44, I have 2 fuel pressure gauges, one before the fuel filter and one at the vp44, and I have become quite the guage hawk.
My normal FP at idle as been about 17psi, however, for the last few days it has been 22-25psi at idle.
What might cause this? And is fuel pressure this high something I should be concerned about.
Old Apr 16, 2011 | 09:34 PM
robinlh's Avatar
Should also mention, I also have a bigline kit installed (for whatever reason that's not showing up in my signature line although I have changed it)
Old Apr 16, 2011 | 11:22 PM
mstep3's Avatar
You running a FASS DDRP 02? That's what I have & I have seen my fuel pressure raise some at times.....Most I have ever seen it raise is about 22-23 psi though....Normally though it will always stay around 19-20 at idle....
Old Apr 17, 2011 | 07:10 AM
dkenny's Avatar
did the temperature change? from cold to warm? your grid heater might have been running before. causing a lower voltage to the pump, thereby reducing the pressure.
just a thought
-dkenny
mnester
Jan 16, 2010 05:01 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
CowboyDave
14
Dec 18, 2006 10:30 AM
redruM Hauler
Dec 14, 2005 05:59 AM
pappygtb
Oct 10, 2003 07:55 PM
