-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Raise in my "normal" Fuel Pressuer (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/raise-my-normal-fuel-pressuer-288647/)
robinlh 04-16-2011 06:31 PM
After replacing my vp44, I have 2 fuel pressure gauges, one before the fuel filter and one at the vp44, and I have become quite the guage hawk.
My normal FP at idle as been about 17psi, however, for the last few days it has been 22-25psi at idle.
What might cause this? And is fuel pressure this high something I should be concerned about.
robinlh 04-16-2011 09:34 PM
Should also mention, I also have a bigline kit installed (for whatever reason that's not showing up in my signature line although I have changed it)
mstep3 04-16-2011 11:22 PM
You running a FASS DDRP 02? That's what I have & I have seen my fuel pressure raise some at times.....Most I have ever seen it raise is about 22-23 psi though....Normally though it will always stay around 19-20 at idle....
dkenny 04-17-2011 07:10 AM
did the temperature change? from cold to warm? your grid heater might have been running before. causing a lower voltage to the pump, thereby reducing the pressure.
just a thought
-dkenny
