Where to Get a Crankshaft Position Sensor
http://hoeslidiesel.com, i also have had good luck these guys fast shippng and half the cost of the dealer
The CEL came on this afternoon and I pulled the code and it's CPS. I'm leaving tomorrow for 800mi round trip. Does it just go out and leave you stranded or what are the issues/symptoms? Thanks.
Not the answer I was looking for but I think I am going to have to gamble on this one. Is it a requirement that the IP be removed prior to installing due to the CPS location or does it just make the job easier? Thank you for the replies.
The Crankshaft position sensor is on the bottom side of the block, behind the starter. Pull the starter and it's right there. One retainer bolt holding it in. Should be able to swap it out along the road if you have to.
The Cam sensor is the one behind the Injection pump. I've heard it's possible to replace it without pulling the IP, just a pain in the neck.
$%&*@!.......ok now I'm confused. Going to have to go back and make sure I heard the guy correct who completed the scan. Cam or crank, cam or crank, cam or crank....I got it!
Again, thank you.
Again, thank you.
James Andres
Dec 20, 2003 04:42 PM
Two Dogs
Jul 11, 2003 09:12 AM
ATEAV8GN
Apr 1, 2003 08:03 AM
