whats normal egt and boost?
Old Jan 24, 2006 | 08:33 PM
HawaiiCTD's Avatar
What should the normal egt's be @
1.idle, 2. cruising and 70mph, 3. wot
What kind of boost psi should i expect?
01 2500 w/ Diesel Dynamics True torque power module, and stage 1 injectors, also 4in exhaust.
Old Jan 24, 2006 | 09:23 PM
blackdiesel's Avatar
Registered
1. 300
2. around 800
3. around 1000
4. up to 20
your results my vary
Old Jan 24, 2006 | 09:52 PM
Beast2B's Avatar
did you install the boost elbow with the box? or mod the wastegate if you have an auto trans?
1. I don't shut the truck off until the EGT drops to 300 PRE-TURBO
2. Flat ground 700-800
3. I can easily pass 1500 if i stay in the throttle.
Two points I'd make:
get a MUCH better breathing air filter and housing, not just a drop-in element.
adjust your wastegate for ~35 boost MAX with an HX35-12 (manual trans) and ~32 MAX for HY35-9 (auto trans)
Old Jan 25, 2006 | 08:46 AM
Mopar1973man's Avatar
1. In cold country this can drop as low as 200-250*F at idle... With a jake on it will idle abou 400-450*F
2. In stock form I running about 800-900*F and boost is about 10 PSI on flat ground.
3. WOT I've seen as high as 1250-1300*F with 19-20 PSI of boost.
Now these temps can vary with the amount of boost you run and also the outside air temp. Like right now this morning its 25*F so I would figure my MAX EGT temps might be about 900*F @ WOT
One last factor in this is altitude. I'm running between 1,300 ft to over 6,500 ft normally so this will offset the EGT and BOOST numbers too.
Old Jan 25, 2006 | 12:41 PM
smokNjoe's Avatar
can you do this w/ a stock 01 24 valve or will it throw codes at me
Old Jan 25, 2006 | 01:09 PM
P.J's Avatar
P.J
It'll toss an overboost code at you.
You need a box to override all those types of codes.
westspeed
Mar 5, 2011 07:46 AM
flashgordon
Mar 26, 2006 01:27 AM
big red psd cc
14
Feb 25, 2005 11:41 PM
DieselMachine
Jan 12, 2004 05:42 PM
prozack
Feb 4, 2003 05:51 PM
