ATF+3 or not?
Old Jan 24, 2006 | 11:01 AM
Ridiculous's Avatar
ATF+3 or not?
hi everyone. i recently just changed the filter and fluid in my tranny and i used ATF+3. but the thing is i thought it was a 46RE tranny and i was wrongly informed about that so i'm wondering if this is the correct fluid to use or should i go on ahead to the dealership for the fluid.
just curious.
thanks all
Old Jan 24, 2006 | 11:12 AM
Mcmopar's Avatar
Fill out your signature, we have no idea what truck you have?
Old Jan 24, 2006 | 11:22 AM
Ridiculous's Avatar
ok i got my signature filled out. sorry bout that. hope it's easier now.
thanks
Old Jan 24, 2006 | 12:20 PM
xblshortcut's Avatar
You should be using ATF+4.
I would recommend flushing your trans fluid with ATF+4 because if you just drain and fill you will not get what is in the T/C.
Old Jan 24, 2006 | 03:03 PM
Ridiculous's Avatar
ok. can you direct me on how to flush my tranny. and can you let me know what the t/c is because i have no idea. but if you could let me know about that flush i will definetily do so and get some ATF+4 in that baby.
thanks
Old Jan 24, 2006 | 05:42 PM
Danderson's Avatar
47re=ATF+3
I've got a 99 2500 47re which you should have also. Your owners manual states ATF+3. ATF+4 was introduced with the 48re, mid-'03. You should be fine.
Old Jan 24, 2006 | 05:48 PM
phox_mulder's Avatar
My 2002 requires ATF+4.
I ran about 10K-15K on about unknown ratio of +3 and +4, no problems.
I was trying to fix a leak at my temp sender, lost 4 quarts, couldn't find +4 so I used +3, leak not fixed.
Tried again, a couple months later, same thing, 4 quarts lost, but found Valvoline Extreme ATF (+4 compliant per the back of the label), and ran that mix for another 5K+.
phox
Old Jan 24, 2006 | 05:51 PM
2500Ram's Avatar
phox
Mine as well check your manual if you have one.
Bill.
Old Jan 24, 2006 | 05:59 PM
I'm pretty sure they changed something in the TC clutch packs for the later years of the 47RE, which required a new formulation of ATF to lessen the "grabbiness" or something like that.
phox
Old Jan 24, 2006 | 09:46 PM
Danderson's Avatar
Oops!
Sorry guys! I guess they must of changed fluid specs. in later 47re's. Even with my DTT upgrade Bill Kondalay recommended ATF+3. Fourteen quarts w/tapped T/C and Mag-hytec,gasket and filter keeps it under $35.00. When I first purchased it a quicky place did an exchange w/Mercon and tranny was not happy. I had it exchanged with Mopar ATF+3 at the dealer($165.00 ouch) Happy tranny but sore wallet.
Old Jan 24, 2006 | 11:19 PM
mopar ken's Avatar
Cool Atf+3?
I was told by oil supply warehouse that ATF+3 is a thing of the past.
It is being replaced by MULTI VEHICLE FLUID.
They said my dodge dealer does not use mopar atf+3.
They use Quaker state multi vehicle fluid in their bulk tanks.
Nice of them to let us know rite?
Old Jan 25, 2006 | 03:00 PM
Olratlr's Avatar
My 2001 calls for ATF+4 but after DTT install running ATF +3
Old Jan 25, 2006 | 03:07 PM
P.J's Avatar
P.J
I just did mine over the weekend, ATF+4 in my 01.5, Love paying $7.50 a quart.
Old Jan 25, 2006 | 03:47 PM
BigBlue's Avatar
My 01.5 requires ATF +4. It's funny though, when I changed to the DTT valve body, they told me to run either +3 or dextron.
Old Jan 25, 2006 | 04:07 PM
RowJ's Avatar
Stephan told you +3??
He told me +4 or Amsoil (meets +4)
I do know Bill seems to prefer +3 or Dexron 3 (no t).
CHEVY S.G. - I would drain the pan only and fill with ATF+4. You will be fine with a mix of +3 & +4... and save some money!!
If your tranny does not like it...will start shifting harder...but have never heard of that happening.
RJ
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
98rammer
Nov 4, 2002 06:23 AM
