What size tires can i fit?
Old 02-02-2004, 06:56 PM
fueler's Avatar
how are you running a 16" rim w/ a 16.5" tire?
Old 02-02-2004, 09:29 PM
bama's Avatar
hey double,,if you go to the bigger coils,you`ll need to get an adjustable track arm also.if you don`t your front end will be pulled over about 1 1/4 inch.iv`e been looking and measuring everybodys trucks thats done this...
Old 02-03-2004, 06:31 AM
gsdog1's Avatar
I am running the same size tires with 4.5" of lift.
2 things - check the backspacing on the 589's and talk with whom ever is mounting the tires (or where you are buying the wheels and tires) to see if the set-up will work. Also, I run nerf bars, and rub slightly on them in a hard right hand turn. It's very manageable.
Matt
sho_shane
03-03-2013 09:52 PM
reasonspj
01-20-2010 07:36 PM
1320
05-29-2009 10:24 PM
bansh-eman
07-21-2008 10:13 PM
sakisaki400
23
12-31-2006 10:17 PM
Quick Reply: What size tires can i fit?
