What next for my 01.....
Since I bought my new to me 01 I have turned her up 75 h.p., replaced lift pump and v.p. 44, installed new gooseneck hitch and it is the most awesome truck...I love it.....Now....My truck is a daily driver and used for transportation to the farm every weekend...125 miles each way What else would you guys recommened next for my rig?
get a better tranny. even though this one may be good do some mild upgrades like triple torque converter and valve body upgrade. Then you'll be able to put a lot more of that power to the ground and it will tow a lot nicer. if your towing a lot too you might think about an exhaust brake. also to keep the heat down you might want to get a bigger downpipe and and open air filter if your K&N is still a box filter. also put a second pusher pump on your truck if you havn't already done so like an aeromotive pump or a fass or something like that. Then you should get guages especially fuel pressure.
guages deffiantly 1st like he said but if you read enoough about diesels don't worry so much at geting super expensive ones. heck i never barley look at mine anymore. just for trans temp numbers i know the egt's sre gonna be through the roof anyways when i get on it and the turbo can hod it's own I don't really care about that number that much. but if i had a 24valve the fuel pressure would be my biggest concern.
CurtisvilleCummins
03-10-2003 02:24 PM
