what is the difference
Old Dec 21, 2006 | 08:33 PM
2002_ctd's Avatar
Question what is the difference
What is the difference betweeen Isb and Isx? How do you know if you have a high output diesel or not? I have a 2002 dodge SLT. The side of the Injector Pump says 245hp at like 3700RPM. Is there a way to set the high idle?
Old Dec 21, 2006 | 09:13 PM
phox_mulder's Avatar
ISB is the engine in our Dodges.
http://www.cummins.com/na/pages/en/p...trucks/isb.cfm
ISX is a bigger engine, heavy duty trucks and such
http://www.cummins.com/na/pages/en/p...trucks/isx.cfm
With your 2002, the only way to have a HO is with a 6 speed manual.
If you have a 5spd manual or automatic transmission, you have no HO.
High idle can be turned on by your Dodge Dealer, or borrow a friends Smarty, load the smarty program, then back to stock,
the stock program in the Smarty has the high idle turned on.
We 2nd genners only get the automatic high idle, when it's darn cold outside,
not the one controlled by the cruise control.
phox
Old Dec 21, 2006 | 09:38 PM
2002_ctd's Avatar
ok I was just wondering because i am going to buy some isb and cummins badges. my truck is a 6 speed manual. Would that have been standard or did someone special order that? i was wondering about the idle because in the last month i started my truck and after about 1 minute it slowly revs up to about 1200 rpm and stays there.didnt know if that was normal or not. I live in wisconsin, sosholuld i invest in a winter grille cover?
Old Dec 21, 2006 | 09:53 PM
fschiola's Avatar
There's a lot of people that have had to get the high idle programed in. It sounds like you've already got it. As far as the grill cover goes, if the coolant temp is staying at the normal operating temp you really don't need it.
Old Dec 21, 2006 | 09:58 PM
Just did some checking and 245hp is the HO, also referred to as the ETH.
ETC being the non HO, 235hp.
That is the High Idle.
I'd get a grill cover, lets you have heat quicker.
I just have some plastic inserts that used to be made by a member here.
phox
CMN_NOT_STROKN
Nov 22, 2024 02:55 PM
GO 4LO
Feb 20, 2003 02:08 PM
Cutthroat
Dec 29, 2002 12:38 PM
j
Nov 23, 2002 05:51 PM
jet
Nov 16, 2002 09:32 PM
