What controls the computer on the vp 44 pump
Is it the pcm, bcm, pcm, or what. I have is intermittent trottle almost like limp mode ( the truck is a 2000 ram 3500) does 2000 ram have limp mode. And i have no codes
Did you reset the APPS and check its resistance per the instal instructions?
Fuel filter?
No codes leads me to believe its a fuel issue, so I would check the fuel pressure pre filter and at the vp44. If your lift pump is TU and the vp is sucking its own fuel you are gonna want to get right on that, or it will start throwing codes for sure...
Fuel filter?
Eric Bertram
Feb 17, 2004 08:45 AM
chrismez
Jan 7, 2004 01:59 PM
RamThatStroker
Dec 28, 2002 06:44 PM
patriot pearl blue
Dec 28, 2002 12:44 PM
