Weird Problems Need Help.
Old Apr 5, 2009 | 06:34 PM
  #31
ScottGregory's Avatar
While digging through a box, I found my scope probes.
I only had a few minutes before it was too dark to work, but I found it interesting to see a 300mV inverted spike on the 5v supply as well as the sensor return (sensor ground). The spike timing exactly matched and followed rpm. I also was able to see ripple from the alternator/rectifiers. Pulling B+ off the altenator eliminated ripple. The ripple increased when it was charging to about 100mV.
All this leads to a ground or loose wire so I will continue searching. I'll have a few days to make some decent probes to check at the ecm connection while the weather clears.
Of course when I had the scope on it it wouldn't act up.
clayprev
Apr 16, 2013 06:15 PM
Bill Kru
Nov 28, 2011 09:08 AM
mttjma2002
Mar 28, 2009 12:13 AM
oldsmokey97
May 16, 2008 08:44 AM
Common
Apr 9, 2008 10:25 PM
