wastegate movement
wastegate movement
How far should the wastegate rod move when i move it by hand, I am trying and it moves about 3/4 inch now that i oiled it up, but when i extend it and let go it wont spring back unless i tap it back. should it not go back by itself?
You should have a VERY hard time moving it by hand, I'd unhook the rod from the wastegate arm and check to make sure that the wastegate moves freely, it could be stuck there and not actually an actuator issue.
actuator is spring loaded to keep the gate closed and intake (boost) will move a diaphram and overcome the spring thus opening the gate,
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
md11jetdriver
Mar 22, 2004 06:08 AM
