Wastegate?
Wastegate?
I keep reading stuff about the wastegate on the bottom of the turbo. Is this thing one stock turbo's or aftermarket ones? What does it do? Im reading people blocking the wastegate which iv figured out builds more boost? Mostly wondering what it is, what it does, and if you can change anything to get a little more boost?
Thanks
Dinner
Thanks
Dinner
Yes your truck has a wastegate, if you look under the intake hose from filter too the turbo ther is a little 5/16 or so hose that leads back to the WG actuator. When boost builds to 21psi it will open bypassing exhaust around turbine housing this keeping boost at a constant value.On a stock truck don't mess with the wastegate you will only overboost engine, ecm will see that and defuel losing power.
Jed
Jed
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
