walberg lp...? and a few other ?'s
westberg lp...? and a few other ?'s
what is this thing?( did an internet search too) Westberg pump about 2inch long and 1 3/4 around(is this just like a carter or something similar?) trying to get some pics up, i have the stanadyne series 100 lift pump on frame and a westberg lp pump right in front of the stock filter, it says it is a 16psi pump, but my gauge is only reading 10-12 idle(6-8 load) and thats the pressure from the stanadyne i would think unless this walberg is shot and the stanadyne cant push through that dead pump? so that pressure reading would have been the vp alone right?
i dont know how this was set up but i have blown the computer on my vp and want to make sure i have good fuel presure when the new vp goes in, how would i check this pump and if it is pushing fuel? i know my stanadyne is good as i just replaced it last fall, i thinkn my system is good, just need to make sure all pumps work and that the pressure stays up for the new vp
I think you're refering to a Walbro pump......
The one I'm using is little larger than you've indicated, was installed on the frame rail, and flows >20 psi so I had to add a regulator/bypass in the line.
I used mine to replace the stock lift pump.
Why two pumps?
Why two pumps?
nope, not it, having a hard time getting my pics in photobucket so i can post them up, no one seems to know anything about my set up, i have asked alot of guys now including Chip at blue chip etc... he knew what the stanadyne was and said it is a very good pump, but didnt know what the Walberg pump was...?
silverbullet830
14
Dec 29, 2006 06:10 PM
GoodoleBob
Sep 27, 2006 11:37 PM
robox
Nov 4, 2005 01:33 AM
1qckdodge
Jul 17, 2005 12:34 AM
banks twinram
Feb 13, 2005 04:09 PM
