Adding resistor due to P1763 code
Old Apr 11, 2010 | 01:26 PM
paulrecore's Avatar
Just had the transmission rebuilt and now get a P1763 code, P1763 Governor Pressure Sensor Voltage Too High. I understand that a resistor can be added to fool the computer. What value should the resistor be and where is the best place to install it? Will a P1763 make it go into limp mode?
2000 Dodge RAM 3500
Old Aug 15, 2010 | 05:15 PM
vrj's Avatar
vrj
I am getting the same code (P1763). What resistor do I need to add and what connector/wire do I tap/solder to install?
Old Aug 15, 2010 | 07:40 PM
dkenny's Avatar
vry,
I like you tag line..since the only gas vehicle we own is a motorcycle..I'm still waiting till a diesel touring bike comes out..
sorry I don't know anything about what Rx value would be needed..
-dkenny
Old Aug 17, 2010 | 11:09 AM
bcbigfoot's Avatar
Are you guys getting any second gear starts from a stop? They are often associated with high trans pressure and the resistor is needed to correct the second speed start.
Old Aug 18, 2010 | 12:12 AM
vrj's Avatar
vrj
I got it resolved. Thx
Old Aug 18, 2010 | 05:21 PM
fschiola's Avatar
Glad you got it fixed! Maybe you could tell us what you found and corrected for future reference?
Old Aug 18, 2010 | 11:20 PM
vrj's Avatar
vrj
I posted the details in a different thread so in a nutshell, my new VB electronics were not working properly. The GPS was not working correctly. Once changed it worked fine.
trik396
Nov 15, 2008 04:24 PM
mogacam
Oct 11, 2008 10:11 PM
99 cummins
Aug 3, 2005 09:25 PM
peanut
Apr 18, 2004 05:19 PM
LTL JON
Apr 9, 2004 07:33 AM
