VP44 swap, how long?
Old May 1, 2008 | 04:49 AM
JonnyThrottle's Avatar
How long does it take to swap a VP44 out for the average person? Any special tools needed? I have looked at a few "how to" articles, but none of them said how long it should take. Thanks!!
Old May 1, 2008 | 06:44 AM
blackdiesel's Avatar
Registered
You will need a little gear puller to pop the drive gear off. The average time for a newbie is 3-4 hours. There is a video floating around here you can watch (search it)
Old May 1, 2008 | 12:59 PM
slowflyer2112's Avatar
Its faster then that. My last one took just over an hour with start up.
Good luck, and don't drop the key.
Old May 1, 2008 | 01:45 PM
RDMueller's Avatar
Definitely watch the video. I think it was done by DieselDan and is posted either here or at TDR (maybe both). If a picture is worth a thousand words, a video is worth a million words! Maybe someone has a link...
Old May 1, 2008 | 01:58 PM
scottsjeeprolet's Avatar
Bring it down to the Cave if you can and we can do it. We've done a couple and actually very easy. We have all the proper tools too.
Old May 1, 2008 | 01:59 PM
Sea:\>Drive's Avatar
X2 what he said. I haven't personally helped but looking forward to learning for when it is time for mine to go.
Old May 1, 2008 | 04:45 PM
2002-5.9's Avatar
Here is the link to a VP44 replacement how to video:
http://youtube.com/watch?v=lPZR5an9LCY
It took me about 3 hours replacing my first (so far) and only vp44.
Old May 1, 2008 | 05:19 PM
klx650a2's Avatar
Those are awesome videos, I do not have to do the vp, but just watching that, I would not be scared attempting it...
Old May 1, 2008 | 05:34 PM
afoulk's Avatar
Its real easy. Unfortunately when I did mine, it took a lot longer than 3-4hours cause my key came loose and fell down in the timing case. I had to take the fan and crank dampner off and take the timing cover off to get it out. Found it wedged between the cam gear and powersteering/vacuum pump gear.
Old May 1, 2008 | 06:43 PM
Registered
He didn't ask how long it took you to change one. I can change one in under an hour and a half, my first one was probably around 3 hours. He asked how long it would take a first timer.
Old May 1, 2008 | 09:37 PM
bentwings's Avatar
The key is a big issue. In every how to they stress not knocking it out. I superglued the last one and that worked ok.
Also make sure you have all the tools available. It doesn't take a lot but there are a couple that are really necessary.
If you go to Harbor Freight they have a cheap crow foot line wrench set that make getting #5 and # 6 lines out and tightened.
Also make sure the batteries are charged as you may have to crank a bit. Try not to burn out the starter. (don't ask how I know)
The small gear puller is necessary to pull the pump gear. I think I paid $6 for mine.
I keep all the tools in nylon bag under the back seat so I could do it at roadside if necessary.
To answer the real question....it shouldn't take more than 4 hours if you have everything.
Old May 2, 2008 | 05:57 AM
afoulk's Avatar
oh, you might wanna also replace the cam position sensor while you have the pump off. Otherwise is a darn near impossible to get at with the pump on. I wish I would have thought to do this when I did mine.
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
