VP44 question
VP44 question
I am not very farmiliar with the VP44 pump. What I was wondering was does the pump regulate psi. I know it has a return line to get rid of excess fuel but if a guy was to replace the stock lift pump with an aftermarket one would you have to run a pressure regulator to control psi if you got a pump that would deliver more than needed. Thanks for any advice/help.<br>
Re:VP44 question
I say use a holley black
.........<br><br>120gph at 15psi .........<br><br>stock pump is 75gph at 15psi.........<br><br><br>you can even get a handy conversion kit at www.wildcatdiesel.com ...........
Guest
Posts: n/a
Re:VP44 question
The VP44 itself regulates fuel flow as far as bypass flow or internally circulated fuel used for cooling and lubrication at around 14 PSI, at which point the internal bypass valve opens, allowing excess fuel to flow back to the tank - and generally accepted figures put desirable PSI at the inlet to the VP44 at about 10 PSI nominal - most of us using added or upgraded pumps usually end up with PSI somewhere around 16-20 PSI at idle at the VP44, down to as much as 12 PSI or so at WOT... Internal seals in the VP44 are reportedly at risk at pressures above 25 PSI or so...
Here's a pic of my added Carter 4600 pusher pump, it's installed back on the frame just in front of the fuel tank - I'm getting 22 PSI at idle, 20 at cruise and 18 WOT...
Re:VP44 question
If I'm correct, the lift pump AND the VP44 both regulate pressure. What causes the lift pump to go out is not really the distance from the tank (though that contributes) is the excessive amount of back pressure on it. The regulator in the lift pump goes out. I know this isn't about the VP44, but just thought I would add that in.
Re:VP44 question
Thanks guys for all you help. Heres what I have have in mind.<br>I have a Chevy 1 ton 4x4 with a supercharged 468 big block with dual dominator carbs. I used a Aeromotive A1000 pump to supply fuel. I have since torn down the motor to put in a stroker kit and upgrade drive line issues. Im thinkin since i have it all apart to yank the pump and regulator (adjustable 3-20 psi) and mount it on my truck bypassing and removing the stock lift pump. The pump has 10AN fittings and I have some braided line left. Just have to take a look at the filter assembly and see how to hook a line to it. Anyone have any ideas? I had considered a Black pump and a change over but I already have the pump and regulator.
Re:VP44 question
Blue, it made a massive amount of power, the engine builders determined around 1000 hp, just the motor not to the ground. They had built a motor just like mine except a different make block for a tractor puller that pulled a mini mod in a cheater class, theyre ususally limited to 410CI. Anyway I cant find a dyno locally so I only have aproximate figures. People who rode with me dont have trouble believeing after a rolling burnout Ive been practicing(still not perfected). I have a line lock and an adjustable proportioning valve so I can attempt Dean Skuza style burnouts. After one or two you gotta stop and get more fuel.
Back to diesel. Im hoping after Christmas I can get that pump on my Dodge and see if I can make something good happen. The pump is rated at 45psi and 500 lb/hr so you can use it for EFI engines. Up to 1300 hp on a carb engine. So I think it shouldn't have a bit of trouble, and you can run diesel through it. Its been good to me so far. I had an outside fuel psi guage on my gasser and it always kept up with it. I had a boost refrenced regulator that increases psi 1:1 per pound of boost if its hooked up. Its not making the kind of boost diesels make though. I also had a fuel log to prevent starvation during WOT. If everything works out Ill just get another pump for my gasser later since its far from a daily driver. Ill keep everybody posted. I just wasnt sure how much pressure the VP44 could take without causing a disaster and costing lots of money.
Erska
17
Mar 6, 2009 09:52 PM
