VP44 problems
Old Oct 22, 2009 | 02:29 PM
jrv15's Avatar
VP44 problems
well, after all the posts that i have written and read i finally got my truck scanned. it gave me the wonderful P 0216 code (injector pump timing malfunction) i also noticed that i have some sort of power programmer that was plugged in under the hood. i ahve attached a picture of it. you can see im my hand the connectors. it looks like it used to have a sticker as to what is was but thats about it. i have looked at all prgrammers that i can and the only one that i can think that it is is the edge EZ.
Old Oct 22, 2009 | 02:36 PM
scooter413's Avatar
looks just like the one I have and it is a edge.
Old Oct 22, 2009 | 02:39 PM
AggieJustin's Avatar
It's basically an Edge EZ. I think there were a couple of companies rebranding and selling the same box, but Edge was the original model.
Old Oct 22, 2009 | 02:49 PM
jrv15's Avatar
i read on teh edge website that there are 3 settings. how do you change the settings as there are no buttons or anything.
Old Oct 22, 2009 | 02:57 PM
Troym61's Avatar
On the box there are 2 small allen hex screws, once they are removed you will see a very small jumper between very small pins, there should be three on top and three on the bottom, the jumper goes between top and bottom. To adjust remove the jumper and move it left to right, ( there are only three adjustments) that is the way it gets adjusted, once you have found which setting is go for you, make sure you put the cover back on the box, and make sure that
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
