Vibration When Coasting
Old Apr 22, 2010 | 09:50 AM
bowhunter57's Avatar
From: I live in Bernville Pa but where I want to live is Colorado
I checked the search and found a lot on vibration's but nothing about a bad vibration when going down hill and off the throttle just coasting. If I give it just a light throttle to put truck under a little load the vibration goes away, if I let off throttle, like free wheeling, the vibration comes back again. Any help would be appreciated Thanks
Old Apr 22, 2010 | 01:10 PM
randallp84's Avatar
Sounds like a U-joint.
Old Apr 22, 2010 | 03:48 PM
Nick02Ram's Avatar
x2, I've had the same problem. push up and down on the driveshaft and see if there is any movement, I've replaced the one on the rear diff twice now in 3 yrs, and the front ones had few needles left in em when I got to them
Old Apr 22, 2010 | 04:03 PM
650HP-CTD's Avatar
I second that vote.....
--Sk
Old Apr 22, 2010 | 05:22 PM
DIESELWRKS's Avatar
SAME. on my rear u-joint both times I felt it in the seat and floor board. at 1900rpms to 2100
Old Apr 22, 2010 | 05:23 PM
randallp84's Avatar
Make sure there is no torque on the driveshaft when you do this. The best way to do it is to jack up both rear wheels and put it in neutral. If the driveshaft is in a bind when you do this, you probably won't be able to tell which u-joint is bad. Sometimes you have to completely remove the driveshaft to find a bad u-joint. I had to remove mine a couple of months ago to figure out that I had a bad u-joint.
Old Apr 24, 2010 | 03:35 PM
Auto Zone ??????
Well I went to Auto Zone yesterday and got 2 new joints for the rear drive shaft. I took the shaft out this morning and installed a new front U joint then I pressed out the rear U joint and went to install the NEW U JOINT or so I thought, when I opened the box and out came an OLD AND VERY USED U-JOINT. I guess someone bought this and used the new joint and returned the old one in the box and got thier money back saying it was the wrong one or something. Well A-Z gave me another joint for it but I had to travel 56 miles round trip to exchange it. I would love to get ahold of the JERK that did this and take my gas money out of his HIDE. LESSON #1 ALWAYS OPEN THE BOX BEFORE LEAVING THE STORE.
But anyhow the new joints did the trick and no more vibrations when coasting.>>>> Thanks Bob
Old Apr 25, 2010 | 12:48 PM
SIXSLUG's Avatar
You can also tell if a u-joint is going bad if there is rust colored dust around the seals.
Old Apr 25, 2010 | 02:56 PM
dieselhillbilly's Avatar
ujoints need a shot of grease every time you service your truck sometimes sooner depending on highway speeds.A dry joint can cause lots damage. Sometimes you dont feel it rightaway.
Old Apr 26, 2010 | 12:35 PM
SIXSLUG's Avatar
Unfortunately the stockers are solids, w/o a zerk.
When I replaced mine I went w/ Spicer solids again for the strength, but many are happy with the greasables. Just make sure the grease channels are open before you install. Some only get grease to two legs of the joint.
Subliminal
Aug 3, 2010 09:57 AM
feveree40
Nov 7, 2007 05:44 PM
arroyojim
Mar 28, 2007 08:48 PM
mestdagh
33
Oct 4, 2005 08:38 PM
TheMoose
Oct 31, 2003 12:06 PM
