very slow to start
Old Feb 5, 2012 | 02:58 PM
trap grease's Avatar
very slow to start
changed pushrod side cover gasket and front cover gaskets last weekend due to oil leaks . to do theses gaskets i had to remove the vp 44 . when i finished the gaskets and tried to prime the vp 44 had no issues .when i primed the injectors with 135 fittings cracked it took a very long time , cranking on for 30 seconds and off for 1 min repeated for about 20 minutes untill injectors would prime . all crush / sealing washers were replaced . my problem is that after sitting for 6 hrs or longer the truck doesnt fire right off it takes about 20 seconds of cranking to fire . when it does fire all is fine plenty of power 14.75 # fuel pressure after filter wot and 20 # boost . I am lost and dont know what could be causing this issue other than the vp 44 . this is the 2nd vp 44 on this truck and it currently has about 250,000 miles on it and has been supplied with 14-15 psi wot since it was installed under warranty at 97000 miles . any help with this issue would be greatly appriciated
Old Feb 6, 2012 | 08:28 PM
phal's Avatar
Air in lines?
Possibly you have air getting into the fuel lines while it is sitting. Did you use aftermnarket crush fittings or Cummins? I had problems with aftermarket crush fittings, specifically the ones that Midwest supplied with my VP44. When you compared the two, they were not the same. I ordered a set from Cummins and the problem went away.
If you believe that to be good, I would take a good look at any connections that may have been disturbed from the fuel filter forward..gm
Old Feb 7, 2012 | 12:52 AM
yes the crush washers on my supply side are cummins and looked identical .the crush washers on return side are aftermarket and appeared better than oem .just to update i have no issue when using the block heater . i shouldnt need it here in the central valey of california . so im leaning towards the grid heaters .
MAC702
Jun 28, 2011 05:18 PM
Bark
Jan 18, 2011 06:54 PM
mr280zxt
Jan 4, 2009 12:29 AM
livingez_123
Jul 26, 2007 06:28 PM
micstep
Mar 6, 2005 10:08 PM
