Valve Adjustment...wow.
Old Mar 17, 2007 | 09:18 AM
Hillcountry's Avatar
I adjusted the valve lash for the first time at 100,000 miles this weekend. Each one was off (loose) by .002-.003 except for #6 exhaust which was still in spec. With everything adjusted the engine is much quieter and I feel like there is better throttle response at the low end...although I admit it is possible that I am looking for stuff here. Will I see improved mileage because it had been dropping (16mpg instead of 18mpg as of a few years ago)? Either way...it was a simple job, although I bashed my knuckles a bit, and the tech stuff here was essential to get it done.
Should I do it every 50,000 or is 100,000 enough? It didn't seem like things were that off except for the fact that now it is so much quieter I wonder if I should make sure the tolerances stay tighter.
Old Mar 17, 2007 | 09:00 PM
dal620's Avatar
yes it can make diferance on the engines performance. where i work we adjusted the valve lash every 100000 miles on our older big cam cummins and on the n-14. mostly the older engines seem to have more effect on power to my recolection. but when i bought my 98 24-v new i asked cummins and they said to adjust them every 100000 miles that would be enough.
Old Mar 17, 2007 | 09:02 PM
dal620's Avatar
forgot to mention that the drivers that checked their fuel milages did state they did notice an increase in fuel milage.
Old Mar 17, 2007 | 10:45 PM
BigBlue's Avatar
I noticed a very slight bump in mileage. Maybe .5. I definately noticed a vastly improved bottom end and a much smoother, quieter engine. The truck was also a let peppier. Mine had ~120k very rough and abused miles on it when I did it.
Old Mar 18, 2007 | 07:51 AM
Thanks guys...I thought maybe I was looking for stuff that wasn't there, but I am glad to hear that there are some improvements. It definitely has more pep in the low end and is more fun to drive. Fuel economy won't increase if I keep driving it like I do though .
Take care
Old Mar 18, 2007 | 09:43 AM
blue285k's Avatar
I did my 99 right after I bought it with right at 99,000 miles. I didn't know the previous history, so I wanted to base line it. It was well within specification with very minor adjustments. Mileage has always been good at 18-19 on this truck (Hand caculated). One of the best things I did was have the PCM programed for the larger tire size.
Steve
Old Mar 18, 2007 | 05:13 PM
99globalwarmer's Avatar
i just adjusted mine makes a major difference in the responce
Old Mar 18, 2007 | 09:20 PM
CobraCTD's Avatar
This sounds like something I may need to do. Can anyone give instructions on how to do this. Or, a link where this is discussed step by step. Thanks.
Old Mar 18, 2007 | 10:06 PM
If you go to the "tech facts" link at the top of the page you can look in the 24valve engine section and you will find the instructions for how to do it. I followed them exclusively. Someone put in a lot of work to post pictures, and great instructions and it was very helpful. Was not difficult, but took some time to get the clearances correct. Patience is the key with this one. Also I'm thinking that the barring tool would have been easier to use to turn the engine over. I don't know where to get one, so I used the 7/8ths bolt on the alternator pulley. It worked, but was labor intensive. I also had a buddy come over so I could bounce ideas off of him and make sure I didn't do anything stupid.
Good luck!
Old Mar 18, 2007 | 11:49 PM
Marine's Avatar
Veteran: Marine Corp
I did mine at 45K and it made a big diff then. I will do them again (145K) when I get back.
Old Mar 19, 2007 | 11:48 AM
RowJ's Avatar
Not trying to be argumentative but...two things to consider.
-Most 01's & 02's I have seen tested have been hardly out much! When you say off .002-.003 are you refering to DTR suggested lash of .010 and .020? If so...you were still well within Cummins specs, which is what most members find.
Cummins specs....
Intake - .006 to .015
Exhaust - .015 to .030
-I noticed no response difference when I adjusted mine and they were all off more than .002 from the .010 & .020.... but I have no idea what the factory settings usually are?
I could see quieter...but more pep???? JMO
RJ
Old Mar 19, 2007 | 12:10 PM
Marine's Avatar
All mine were within spec, but althroughout the range.
It probably didn't make it peppier, but it sure seemed like it! In fact, even when I wash my truck, it feels like it has more pep. Lol
Old Mar 19, 2007 | 02:10 PM
Good question...I should have been more clear. I stopped measuring past .013 or .015 (or .022 for the exhaust). I brought them all back to .010 and .020. So they could have been off more. I didn't intend to mislead...I had everything disassembled and figured I would put it back to spec. It is much quieter. I do feel there is more pep though...not much just right off idle it picks up better and seems to hold on hills much better too. I wouldn't say I picked up any power, it just has a tighter feel to it.
A reasonable question though. Thanks.
CTD03
Nov 22, 2008 09:58 AM
roadgeneral
Oct 17, 2007 06:54 PM
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
getblown5.9
Dec 18, 2005 08:28 PM
