vacuum pump seal link
Would anyone have a link/address/suggestion on where I could find the procedure, tools, etc. I would need to replace the vac pump seal on an '01? I did a search, but only found this for a '98. There was some arguement on this thread about the process being the same for both models. 'Preciate ya.
On an 01 I did awile back I separated the pwr steer pump from the vac pump in the truck and was able to get it out of the way enough to remove the vac pump. A must have is a 15mm chrome swivel socket as one of the nuts is very tight to get at. An impact swivel won't flex enough to access (bulky also). Once you get the vac pump out it's pretty straight forward.
jimbo486
05-08-2016 06:07 PM
yomitch
04-21-2003 06:28 PM
