vaccuum pump seal kit.
Old May 4, 2010 | 09:38 PM
yfz450guy's Avatar
would there happen to be anybody in the vancouver, wa. / portland, or. area that wants to make a few dollars and do the seal kit for me? *********** wants $450 +parts.
i can get the kit from genos and pay someone to put it in.
i don't have $500 to throw at it right now. but can swing about $200.
Old May 4, 2010 | 10:03 PM
johnh's Avatar
get the kit from cummins ,$10.00 or less
it's so easy I'd do it just for fun..... really. three bolts and one hydraulic pressure and two return lines
if you decide to do it yourself don't try to remove the return lines from the power steering pump. just cut them right at the barbs on the pump....put it on the bench and disassemble
Old May 4, 2010 | 11:55 PM
nickg's Avatar
very simple to do, if you can get the pump off, you can replace the seal, its that easy, Cummins sells the kit its cheap and comes with instructions (at least mine did).
Old May 5, 2010 | 12:34 AM
yfz450guy's Avatar
everybody is saying that it is sooo easy then why do they charge soo much to fix it.
does anyone want to help?
Old May 5, 2010 | 08:00 AM
nickg's Avatar
its the same for a VP some shops charge so much because it sounds intimidating, when in fact it takes maybe 2hrs. If your not confident then I'm sure you can find someone to do it.
There is also another company out there(name excapes me) that even provides a video of the repair, including the seal driver, I think the price was around 60$ a search should find it
Old May 5, 2010 | 08:15 AM
rebal's Avatar
If you buy the seal kit from Cummins it will come with instruction. real east you really only need to make sure the seal gos in the right direction . on a scale of 1-10 its a 4-5 the only tools are a few metric wrenches and 2 large sockets to drive the seal in and out and a hammer
Old May 5, 2010 | 08:52 AM
johnh's Avatar
do it yourself, here's how............
https://www.dieseltruckresource.com/...d-t268138.html
Old May 8, 2010 | 11:13 PM
mini14's Avatar
i did mine a few years ago, u dont have to cut any lines, just slide the ps pump off and let it hang there. put new seals in and align the tabs and slide the ps pump back onto the vacuum pump.
Old May 9, 2010 | 07:39 AM
Andy505's Avatar
Same here, but I did mine a few months ago. Still, it was easy and no need to do anything to the ps pump but move it out of the way.
Old May 9, 2010 | 10:38 AM
ldornak's Avatar
I installed the seal kit in mine yesterday while I was replacing my steering box. It was easy to pull the pump assembly from the bottom with everything out of the way. The instructions that come with the $9 kit from Cummins and a couple of sockets is all you need. I've heard some on here mention a $60 kit that comes with a DVD and tools needed to press the seals out. Save yourself some money and buy the $9 kit from Cummins.
Old May 9, 2010 | 01:25 PM
Junk Man's Avatar
Sometimes getting the vac & ps pumps lined back up can be a problem during which time you can mess up the new seal. Easy enough to pull both pumps as a unit - your choice.
Old May 15, 2010 | 02:46 AM
OUTDOORSMAN's Avatar
5 or 6 years ago I bought the kit from fixinrams. Back then I could not find as much info about replacing the seal as there is on this site now. The fixin rams kit was highly reccomended to me then. I reccomend it today. If you need a confidence boost the video will help. I even made a call to them and got some help over the phone. Great guy. Great kit. I have put 100,000 mi on this seal and no leaks. No problem. Check out the site.
http://www.fixinrams.com/
good luck
Old May 15, 2010 | 10:12 PM
mini14's Avatar
lining the tabs up is super easy, grease it up before insertion :-)
Mule Skinner
Apr 8, 2011 11:49 AM
NoSparkplugs
Jun 24, 2009 07:08 PM
DodgeRamdiese01
Jun 19, 2009 12:13 AM
guitarman
May 3, 2009 11:21 AM
fitzer
Sep 3, 2003 09:53 PM
