Two Questions
Old Mar 17, 2009 | 09:33 PM
progrower's Avatar
Two Questions
I just purchased the truck listed below in Dec. with 128k on it. Now at 130k I have noticed that on a warm start up it smokes black for a couple of seconds and then clears up. Is this normal? Also I was wondering if there was a way to tell if the VP is still the factory orginal. I noticed mine still has the yellow void sticker on the connector and it has been cut at some time or other.
Thanks.
Old Mar 17, 2009 | 11:51 PM
chainzaw's Avatar
All of our diesels let out a puff of smoke upon start up. Doesn't matter if their cold or warm. It's possible that it's been replaced. Consider yourself lucky if it has been.
Old Mar 18, 2009 | 09:01 AM
progrower's Avatar
Thanks chainzaw. I hope it's been replaced. I found out the LP was dead soon
after I bought the truck and put the airdog on right away. I had only 3-4 psi at idle. Hope it wasnt running to long that way.
Old Mar 18, 2009 | 02:40 PM
mini14's Avatar
when it starts puffing white then start to worry
Old Mar 18, 2009 | 06:24 PM
wurkenman's Avatar
There should be a reman sticker on the pump. There are no NEW pumps to be had.
outside304
Jun 12, 2010 06:14 PM
Totallyrad
May 23, 2010 12:42 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
crobtex
Oct 15, 2006 09:59 PM
Dieseldude4x4
Jan 4, 2003 03:07 PM
