turbo help
Old Feb 9, 2008 | 08:34 PM
edy's Avatar
edy
turbo help
today i was looking over my turbo and i noticed that when i spun it with my fingers it has a stiff spot what is this it aint normal. Any help or suggestions is greatly appreciated
Old Feb 9, 2008 | 10:53 PM
Clunk's Avatar
Looks like you're gonna get a turbo upgrade...looking at your signature, it'll probably run lots better & cooler too.
Old Feb 10, 2008 | 04:16 AM
dozer12216's Avatar
I can hardly figure a rough spot turning(????). Does it have end play or hit the housing with side force? Is there score marks on housing? Is it oily, smoke or use oil in excess?
It spins on a double sided bushings.
Old Feb 10, 2008 | 12:11 PM
gmctd's Avatar
Correct - it has full-floating bearings - but the hard spot could be scored shaft, soot build-up in the turbine housing, ect - crank it up, bring engine up to operating temps, shut it down, then check for shaft spin
Old Feb 10, 2008 | 02:30 PM
SIXSLUG's Avatar
When warm mine spins pretty freely. When cold I was installing the heat shield for my BHAF I wiped out the outlet before reinstalling the air tube and it felt pretty sluggish and had a little spot where it felt like it hung up, but not rough or sticky.
Old Feb 11, 2008 | 07:17 PM
edy's Avatar
edy
yeah i think its fine =]
Old Feb 11, 2008 | 07:54 PM
ronnyenns's Avatar
I need help with my turbo i have a s300 66/14 pdr turbo and when i throtlle up i hear something like skreching from the turbo but it spins 100% freely, so today i removed the filtler and saw something got into the intake of the turbo the wheel has a little damage, i used to have 45 psi of boost now i only get 30 and it makes a wired sound..would it help putting in a new wheel? here are some pics..
Attached Thumbnails turbo help-11022008072.jpg   turbo help-11022008073.jpg   turbo help-11022008068.jpg
CumminsRedneck
Jul 6, 2013 03:20 PM
Ada381
Feb 10, 2008 07:58 AM
smalltownTPull
Aug 26, 2004 10:55 PM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
