Turbo Extremely Loud Now
Old May 14, 2003 | 11:51 AM
dodgeman01's Avatar
Re:Turbo Extremely Loud Now
Must be the wire : Maybe the filter pipeing ahs a hole in it or maybe came loose??? Only reason I can think of. <br>DM01
Old May 14, 2003 | 12:00 PM
red_rattler's Avatar
I started hearing the exaust drone noise here recently. I thought it was the turbo for a while, Like you said it just started all at once, Is it a high pitch whistle. it could be the exaust.
Old May 14, 2003 | 12:28 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Did you just get a haircut and uncover your ears? ;D<br><br>Maybe since the weather is getting warmer you are hearing that fan kick in more now as well. Just another guess here.
Old May 14, 2003 | 03:45 PM
phox_mulder's Avatar
Since you cut the hole for the Scotty II, maybe the insulation flap has shifted?<br><br><br>phox
Old May 14, 2003 | 06:58 PM
drawson's Avatar
Jack, One of the Scotty 2 I drilled the hole for had an AFE filter start to come aprt at the seams and it was like a turbo noise. Check the filter out before too long....
Old May 15, 2003 | 12:27 PM
FMF MX's Avatar
Jack -<br><br>I too noticed the turbo getting louder, and determined it to be the A/C lever in the defrost/floorboard setting. For some reason, it opens a vent that sounds like it is right near the hole in firewall for the scotty II. It only gets louder when in that position. Just a thought.
Old May 15, 2003 | 04:13 PM
Olratlr's Avatar
I too noticed the turbo getting louder, and determined it to be the A/C lever in the defrost/floorboard setting. For some reason, it opens a vent that sounds like it is right near the hole in firewall for the scotty II. It only gets louder when in that position. Just a thought. Mine does just like what was stated<br>above. <br>
Old May 15, 2003 | 06:11 PM
TPilaske's Avatar
[quote author=Lary Ellis (Top) link=board=4;threadid=14723;start=0#138082 date=1052933338]<br>Did you just get a haircut and uncover your ears? ;D<br>[/quote]<br><br><br>Jack got rid of the mullet? ??? <br><br> ;D
Old May 16, 2003 | 12:33 PM
FMF MX's Avatar
Jack -<br><br>You bet, hope it helps..
Wulfdiesel
Sep 20, 2007 04:04 PM
TxDiesel007
Apr 12, 2006 09:47 PM
PeytonMaterne
Feb 3, 2006 11:39 AM
Mcmopar
Dec 11, 2004 03:39 AM
GreenMachine5.0
Nov 27, 2003 10:45 AM
