Extremely High Idle, Missing, and Smoke
Old Nov 26, 2003 | 04:18 PM
GreenMachine5.0's Avatar
Came to a stop light today and the idle kept pushing the truck (auto) stoped the truck but it was pushing and pushing. Pulled over and put it in neutral, it idled at 1500 rpms.
Sounds like it oculd be missing.
WHen driving, once i get on the throttle its like it should be, but theres hesitation when i only put the pedal in a little.
when in neutral and giving it gas, smoke pours out of the exhaust.
HELP?
Thanks
Josh
Old Nov 26, 2003 | 04:25 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Extremely High Idle, Missing, and Smoke
What year truck?
Any modifications?
Old Nov 26, 2003 | 04:37 PM
99 24v with edge, and HO injectors, and straightpipe.
I just got the truck, so i don't know too much about it.
Seems like it woule be the idle position sensor on a gas engine.
Old Nov 26, 2003 | 05:18 PM
DODGE4X4's Avatar
Take out your Edge and see what it runs like. It might have gone out on you.
Old Nov 26, 2003 | 05:26 PM
Undid the edge, no difference. Took the battery cables off, no difference, except now I have a cehck engine light.
CPS???
Josh
Old Nov 26, 2003 | 05:51 PM
DODGE4X4's Avatar
Check the engine codes to see what they say.
Old Nov 26, 2003 | 05:54 PM
OK stupid question,,,but how do i do that? I tried turning the key three times like my jeep, but no good.
Josh
Old Nov 26, 2003 | 06:26 PM
DODGE4X4's Avatar
If you turn the key On/Off three times it should start to give you the codes. It will read out in you odometer.
Old Nov 26, 2003 | 06:47 PM
Shovelhead's Avatar
That procedure started in the mid '99 model year.
Some do, some don't.
Might have to check out the local auto parts chain.
Most of the larger ones will pull and erase codes for free.
Old Nov 26, 2003 | 08:34 PM
crobtex's Avatar
My '99 will run the codes on the odometer by holding the button in for 5 or 10 seconds, then turning the key on while still holding the button in. I don't think I've ever had a code set because it cycles thru and then flashes all the instrument lights, pegs the gauges, then returns to normal. It goes thru the sequance without stopping. I picked it up on one the threads here.
CR
Old Nov 26, 2003 | 08:51 PM
Shovelhead's Avatar
That's the test for the instument panel circuits.
Old Nov 26, 2003 | 08:52 PM
jrs_dodge_diesel's Avatar
Just a thought. Could the APPS be a likely culptit?
Old Nov 27, 2003 | 08:01 AM
Its one of the sensors I think...apps, cps or something like that. I"m gonna start witht he cheapest sensor and go from there.
Is it safe to drive when its smoking and such like it is?
The nearest auto place is about 10 miles away.
Thanks
Josh
Old Nov 27, 2003 | 10:11 AM
Shovelhead's Avatar
I'd give 'em a call first and see if they'll pull the codes for you.
Why buy parts you don't need?
Old Nov 27, 2003 | 10:40 AM
tmiller24's Avatar
One of my coworkers truck was acting this way and it turned out to be the Crank position sensor.
