truck giving CEL
P1594 is charging system voltage too high.
P500 is no vehicle speed sensor signal. (you can also get it by spinning the rear wheels)
P1693 - companion code in ECM
Loose your tach at all? if so, look at cps
Tach seems solid, i have noticed, that my truck seems like it is "hunting" gears while cruising on flat terrain @ speeds between 40-60 mph...Also forgot to mention, i have good fuel pressure 12psi cruising and around 8-9 @WOT
due to the fact that my truck was "hunting" gears, i cleaned all my grounds, w/exception of the two under the head-liner...i think there were 15-16 other grounds, i also ordered and installed the "timbo APPS" replacement...and i believe this has rectified my CEL issue, as it has not occoured in over a week (was happening daily) ...i also replaced both neg. batter clamps while checking/cleaning my grounds...i have not had the p1594 code since....
had several people tell me that the "APPS" would not throw a "CEL" well i believe it was the cause of the error code, time will tell, but for now i'm making smoke with out concern
MrSuzuki
Jun 16, 2009 12:23 AM
boaterman
Oct 15, 2008 10:44 AM
Hillbilly Delux
Mar 20, 2008 05:01 PM
Ripper406
Apr 6, 2005 07:38 PM
