Tranny Giving Up The Ghost
Old Apr 27, 2005 | 08:57 AM
HydraulicGuy's Avatar
Question Tranny Giving Up The Ghost
After pulling a somewhat heavy load for 15-20 miles my tranny started to shutter and shake when I stepped on the pedal to far. I had it locked out of overdrive running around 50 to 60 mph. I have 184,000 on it. No issues other than solenoids and filter / fluid changes. After getting home I unhooked and took it down the road. From a dead stop it felt good, but when going from 3rd to 4th I could make it shake and chatter. Any ideas on possible causes? I've been expecting it to go sometime but not today. Thanks!
Old Apr 27, 2005 | 02:50 PM
Mike D's Avatar
Sounds like the torque converter is slipping. Once you slip it a couple of times it usually needs to be replaced. You could try to add a shift kit which will increase line pressure for the lock up. I would also check the condition of the fluid to see if it got burnt. With the mileage you have on that tranny, it might not be a bad idea to pull the transmission and do a rebuild.
Old Apr 27, 2005 | 03:44 PM
Mcmopar's Avatar
Throw a good shift kit in it and BE CAREFUL with it and it will be OK for a while. Are you sure the lockup solonoid isn't causing the problem?
dezlsmkr
Jul 26, 2005 08:25 PM
FiverBob
18
Aug 1, 2003 12:18 PM
FiverBob
Dec 16, 2002 07:19 PM
FiverBob
55
Dec 13, 2002 05:45 PM
