Truck dies when shifting fr. Reverse to Drive
Old Jun 11, 2010 | 01:27 PM
SilverDollar's Avatar
Truck dies when shifting from Reverse to Drive while changing direction in driveway or parking lot. Starts right back up, no other symptoms. Any advice, TIA. Will change FASS filters and check codes when I get time.
SilverDollar
Old Jun 17, 2010 | 12:31 PM
Has anyone else had this problem?
Old Jun 17, 2010 | 05:50 PM
Doj Dewd's Avatar
i started having a similar issue after a built tranny was installed. my problem is when the truck is still cold it stalls as soon as it gets put into any gear forward or reverse . . . haven't investigated it yet so still need to get it worked out.
Old Jun 18, 2010 | 04:58 PM
snowwjob1's Avatar
I had the same problem if i got the truck rolling in neatural, then go into gear it wouldn't stall. It was the torque converter stuck in lock up and would stall the engine. I only had 8k on the rebuit tranny and dodge replaced the tq converter.
chainzaw
Dec 21, 2011 10:43 PM
90 power ram
Oct 6, 2011 08:04 PM
RockysInMyBlood
Nov 17, 2008 10:22 AM
DynamicalyUnstable
Nov 13, 2008 09:36 PM
Teach
Apr 8, 2006 11:16 PM
