Engine dies when shifting in rev. or drive.
Old Dec 14, 2011 | 11:08 PM
chainzaw's Avatar
I have and Automatic tranny. And in October I finally bought and installed myself a brand new set of Mach 1.6 injectors. Sense then, after starting the truck in the morning, I'll let her idle for 10 to 20 seconds and shift to reverse or drive, it doesn't matter, and the truck will either stall or come close to it. I can watch the RPM gauge drop down to 300 or 400 before it comes back up and idles fine after that at 800. Once the engine warms up it really isn't an issue. It still kicks into gear a little rough but the engine won't stall.
So what is going on and what can i do to fix it? This never happened before the injector install. I'm fairly certain I did everything correct.
Thanks for the help
Old Dec 17, 2011 | 05:52 PM
roysleight's Avatar
I'm interested in any answers as well. I've noticed that when the weather is cold since I got my Goerend tranny I will have the same problem. The tq is so tight that it will almost stall the engine until it warms up the fluid. Yours didn't do that until you changed injectors? I'm thinking of getting the same injectors soon. How do you like them as far as performance. Glad to see someone nearby, I'm up in Hat Creek.
Old Dec 17, 2011 | 06:42 PM
johnh's Avatar
it's possible the lock up converter solenoid may be malfunctioning
Old Dec 18, 2011 | 12:42 PM
roysleight's Avatar
Chainzaw, did this ever happen before the new injectors? Is this the first cold weather since you got the Goerend tranny? Still would like to know if the mach 1.6's made much of a difference.
Old Dec 18, 2011 | 07:38 PM
97Dodge's Avatar
I had this problem with my 97 ,I found that the idle speed was just a little to low. Turned it up just a little and havent had a problem since . what happens is the screw that it rest on for idle wears down over time . . Hope that helps you guys
Old Dec 18, 2011 | 11:59 PM
chainzaw's Avatar
Yes this started the first time i put the truck in Drive after the injector install. I've had the tranny for 3 years now and it's never done this before.
97Dodge I'm not sure that can help me because you have a full mechanical pump and mine is electronic.
It seems to me that I have read of this problem a few years before but I can't remember what the solution was. I do know if I increase the RPMs a little before I shift it won't stall.
Old Dec 19, 2011 | 12:54 PM
97Dodge's Avatar
yes diffrent pumps but you still have a stop screw under the black cover over the TPS , not sure if that helps you or not but I think 800RPMs is a little to low for the Auto tranny . Hope that helps
Old Dec 19, 2011 | 06:45 PM
Busboy's Avatar
Perhaps the IAT is dirty and not reading correctly.
Old Dec 19, 2011 | 06:50 PM
rickf's Avatar
That screw is not for idle adjustment. It is to set the baseline voltage for the throttle sensor. Idle is completely controlled by the ECM. You can not change it.
Rick
Old Dec 19, 2011 | 07:05 PM
98ramcummmins's Avatar
Im dealing with the same issue!
Old Dec 20, 2011 | 12:46 PM
Busboy's Avatar
Clean the IAT, this is the ONLY thing that tells the ECM what the temperature of the intake air is.
Old Dec 21, 2011 | 10:43 PM
chainzaw's Avatar
I'll clean it the next chance i get. probably not till this weekend. But I don't see why the air temp would make any difference.
It just seems to me that the injectors are changing how my engine idles. And when I add a high compression engine+cold block+strong torque converter+aftermarket injectors the equation is a stall, or close to it, when shifted into gear.
Like I've said this never occurs when the engine is warm, regardless of outside temperature.
tfdcruiser
Apr 12, 2020 01:26 PM
manolomanza
Aug 13, 2015 08:28 PM
SilverDollar
Jun 18, 2010 04:58 PM
RockysInMyBlood
Nov 17, 2008 10:22 AM
jjj_85
Nov 19, 2006 06:07 PM
